S
Shellioness Love
Hello, I need to know if there is a ground wire connected to a metal receptacle box already and I replace the receptacle and it has a green screw for grounding, do i remove the ground and connect to receptacle? The ground has another ground twisted around it. Do i untwist and connect one to the receptacle or just leave as is and only connect black and white wires?
Also the clip for the ground wire connected to the box is broken
What you need to do is use your ground wire to wrap the ground wire around the green screw in the box and then hook it to the receptacle. Use both of the ground wires twisted together You can untwist them and pig tail 2 grounds wires with a wire nut to the existing grounds and hook 1 ground wire to box and the other ground wire to the receptacle
