Discuss How to identify the runners of a 4-way switch in the UK Electrical Forum area at ElectriciansForums.net
bushyiii
Moved into a new home and my wife wanted all the existing outlets and switches to be modern design, LEVITON decora to be specific.
Everything has been changed including multiple 3-way circuits, all are working correctly. When tackling the only 4-way I ran into the problem. The 4-way colored screw orientation is different from the one to be replaced. Fearing a problem I took pictures of the existing wired connections. Then installed the new 4-way keeping the same wire orientation. It doesn't work.
Is there a way I can determine how to identify the wires so I can connect them to the correct screws? There isn't anything in the LEVITON packaging that identifies the 4-way terminals. I will check LEVITONS website for that info.
Thanks in advance
Thanks in advance
I tried attaching pictures but wasn't permitted. The original 4-way switch had a Black and Bronze screw on one side and the same on the other, the new 4-way has two Black screws on one side and two Bronze on the other.
Reply to How to identify the runners of a 4-way switch in the UK Electrical Forum area at ElectriciansForums.net
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Hi, Need some help with an odd setup. I have a large room with many lights that i separated into 2 sets. In Box 1 there is the 14/2 power in, 2...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hello - Looking for assistance regarding a problem with my three way switch what was working over the past four months with no problems until this...
