Discuss How to repair this snapped wire? in the DIY Electrical Advice area at ElectriciansForums.net
Hi - I know this is in my car engine bay, but I'm hoping the logic for repairing it will be similar.
The attached photo shows the problem - this is for my car's horn. I have tried soldering it but there is so little wire available in the white connector that it doesn't make a strong enough connection. The white connector doesn't come apart.
I'd really appreciate any advice here as my car's MOT is due shortly and this has just happened!
Many thanks
Your best option is to extract the terminal from the socket and directly solder to it
It looks like there is a lot of verdigris on the terminal so it may need a good clean and plenty of flux to solder a cable to it
Thanks for the quick reply! That's a good idea, thanks - I'll see if I can pull/push the terminal out of the connector.
If it comes to it you could always dispense with the plug/socket and solder+heatshrink the wires.
The terminals are normally held in with barbs on the side of the terminal a couple of pins can be used to move the barbs back to allow the terminal to be pushed out in the absence of the specialist removal tools
Reply to How to repair this snapped wire? in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone. I have recently bought my first car with intention to restore it - the vehicle had been on fire a little bit due to electrical...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
U
I am as newbe DIY as it gets when it comes to electrical work. Here is my issue at my home. I have a light switch which controls the recess...
upillai4444
U
