C
cledis
Hi, I have a problem with kitchen spots, every time i switch on the out side security light the kitchen spots light up very dimly hence i can not leave the security light on.
Thanks in advance for any comments.
Hi Cledis, welcome to the forum.
I've made your post into a thread of its own for you.
Can you give some more info? What type of fittings are the kitchen spotlights and lamps LED's? Has the fault been happening since they were installed or did it start happening recently?
Sounds very much like a back feed off the neutral from the outside light is connected to the switch side of the kitchen lights.
sounds to me like a wrong connection. If its at the end of the line it could be that your 'sparks' has connected it incorrectly and effectively connected them in series. this would account for the dimming nature of the problem. im presuming this is a new problem so get your sparks back to correct it.
The fault has been there since we moved in 6 months ago, i am on holiday at the moment so will update with more info when i get back.
Cheers
if the kitchen spots are LEDs, then it could be induced voltage with the cables running close together.
Had the problem for six months then wait until your on holiday to look into to it. Grab a cold one then get an electrician to deal with it when your home. Shouldn't be anything to serious.
