Discuss I have a stiebel CNS 300 wall heater. in the UK Electrical Forum area at ElectriciansForums.net
Henry1266
Hi Regarding the heater and the 4 wires .Will I be able to put a plug on this heater.
What will I do with the fourth black wire ?
I have never come across this before just need some advice please
The manual tells you about the connections:
1 Neutral conductor = blue
2 Live = brown
3 Earth conductor = green/yellow
4 Control cable = black
There are 3 possible ways to connect the appliance:
- Appliance connection without control cable
Unregulated appliance. The control cable is not connected. In this case, insulate the control cable.
- Temperature setback via control cable
To reduce the temperature to the set setback temperature, the black control cable is activated via an external electronic contact (e.g. a time switch).
- Control cable connected to external control unit
The appliance can be connected to any control unit that issues the following waveforms as control signals.
[See table in the manual for more info]
Reply to I have a stiebel CNS 300 wall heater. in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi all I'm after some advice on 2 way CU in a garden office which is 'buzzing' when I turn on or increase the tempreture of the wall mounted...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
