Discuss I need advice on fcu for UFH in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
local isolation is a good idea. maybe there's a cupboard close to put a FCU in. I'm assuming the it's no more then 3kW (13).
Reply to I need advice on fcu for UFH in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
