M
Mr Mark Sparks
hi
i have now finished importing all my cd's into my itunes library,when viewing the library all the compilation albums show up multiple times with 1 track on each, so once per artist , how do i merge these so the album only shows once with all tracks.
if you can help pm me your number and i will call you if its hard to explain in writing
cheers mark
if you look at this you will see the faithless album apears 3 times the 1st one is the majority of the album then the other 2 are the two tracks that feature other artists.
all the albums with more than 1 artist are like this
my wifes Brandy album features a different artist on every track so apears 12 times
I have and as long as all the tracks are on the same album then they appear as the same album.
Only time i have duplicates, is if the track is on an album then you put a compilation album on afterwards
There is a function in there to show duplicates and you can delete them.
Im guessing you know about playlists etc?
Mr Mark Sparks,
Mr Mark Sparks,
