Discuss If you didn’t have shears how would ? in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
Cut meter tails and other thick cables
Junior hacksaw
Or
Nibble with side cutters until all the way through
that's a bit like saying if you didn't have shoes, would you hobble on the cobbles?
Hacksaw for me for large cables like SWA cores if not the luxury of ratchet croppers.
I suppose a junior for smaller tails if not got any croppers to hand, but I always do so I wouldn't know really. Cheap enough to have a few pairs.
When the shears or ratchet cutters were awol I have resorted to Hacksaw, angle grinder or even jigsaw in the past.
I'm one of those weird people who still uses a jigsaw for some trunking work.
Other than the horrendous noise, what's the problem with using a jigsaw on trunking? Tool for the job in many circumstances?
That's even worse!! I own a multitool, bit it's one of those bits of kit that are definitely in the 'emergency, nothing else can do it' category! Very very useful, occasionly! I hate the racket so much I try not to use it!
Been on jobs where they don't stop all day, sends me nuts!
Yep! Ummmmmmmmm yep! Agian? And agian untill I enter 5 words when one would’ve been sufficient to convey what I wanted to reply :oops:
Almost forgot, have some Rothenburger plastic pipe cutters that i use for YT2 in the summer, in winter will shatter it rather than cut.
Reply to If you didn’t have shears how would ? in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
I would like to get some information on what protection is on a multi meter when accidentally testing a live circuit while the meter is on the...
During an EICR meter tails were found entering the cavity and coming down a stud wall to a consumer unit about 5 meters (direct distance) away...
5K
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
