JD6400
Mentor
Just wondering how many others have come across either very dubious looking or just down right bent connections , and what have you done about it afterwards ?
You mean like go go power pinchers?....seen evidence of it stacks of times usually low class rents that do it. Funny thing is n all....they think you dont know what they`v been up to..lol....:toetap05:
Well I installed shower for a customer, DNO came along and did all the disconnections for me asked to phone him on his mob when finished I'd be as he was in the area all day, new tails to a seperate shower CU, stood back and had a look, I only connected it up to the incoming tail ends missing out the bloody meter, so it is easy to
Pict
Sometimes though they appear to have at least a basic understanding of electrical installations......makes you wonder if any of em are deemed as "competent persons" by a higher power...lol.......
Last time I saw a non working meter was a multi millionaires warehouse even had someone pass the gas meter I was picking something up and"noticed" his indiscretion
A while ago I was taken out for a drink by a “mate”. “You can do live jointing can’t you?” He only wanted me to put a breach joint in his supply cable to give a second un-metered supply to his house. You can guess the reply!
id guess it wasnt 'make it a double' pardon the pun..:wacko:
went to a punters house the other week, he rents it out, a room was converted to a grow room.
Anyhow, the meter had been bypassed in such a professional way, I was really impressed.
They had installed a 2 way rcd cons unit , supplied from a home drilled in the cutout, and connected to the fused side of the supply, 16mm green and yellow. you could not see it had been done! And the G/Y had me stumped at first looks.
Yep well this place we went to the other week (it was unoccupied at the time)....well they had used the 16mm G/Y to bridge the meter thus rendering the installation with NO means of earthing at all...lol.ffs...:saddam:
I was talking to another contractor the other day , for the life of me can not remember who !!!
But anyway they had gone out to quote a solar system on a farm come industrial estate , they were shown around the site and told the client had two incomers , one in a large steel portal barn come stables paid for by himself and another across the other side of the site in a ex chicken shed which is now units that is paid for by the tenants .
While walking around he pointed out a transformer that had been moved across to the other side of one of his farm roads to make way for a new building , this had been done by some chaps from freedom who had done it on the QT in return for renting one of his units for six months or so while they were upgrading the local network , they then went into the unit that they had been using which he wanted the system on , which they also were supposed to put a new sub main into from the stables as part of the rent .
Anyway this contractor looks at the incomer and notices that it has a proper head which is pme , tails , meter and all sealed !
Say's to the farmer that it is proper incomer and he needs the mpan to start the DNO paperwork , farmer say's he has no bills or mpan ?
Turns out they cut in to the incomer just out side the shed and branch jointed it on the QT to save running the swa sub main the 200m meters from the stables as agreed !
Needless to say they didn't bother with the solar !
The contractor also looks after one of the neighbouring farms and about six months before had gone out to emergency call out because of a " sparking cable " on arrival it turns out that the freedom boys had been in a couple of mobile homes at the back of the farm and they run a three phase twisted aluminium overhead cable tapped of before the meter with their clamps and draped for near on 200m over four steel portal framed barns then through a piece of scaffold tube across between two barns then into a proper three phase head and into the caravans .
The sparking was coming from where the cable was wedged up against a stanchion as it went into to scaf tube , and every time they drove over the scaf tube it shorted out between them !
It was a livestock farm with each shed full of barley beef bulls !!!!
The freedom boys had buggered of a couple of months before and just left it like that !
I used to shop them all. My electric bill is extortionate enough without paying for these parasites as well, there is no such thing as free electric. Every now and again, the power companies do an audit on how much they have produced how much has been paid for, and then work out how much has gone missing, they then whack the cost of the missing onto mine and yours bills.
Have a look at the UKRPA website.
Cheers..........Howard
We went into a rented the other week caus his kettle kept tripping the RCD..."but its new kettle" he says....downt meen owt i said....Leakege RCD wont stay in with that on it so gets to the dis board and finds the front off it with a length of 10mm t&e stashed down the side of the cubboard and evidence of em goin into the cutout....little b&stards....needles to say the front was securely replaced back on the board with instructions not to tamper with it and the 10mm was confiscated....like you howard on this...should have reported it to the letting agency together with my intentions of notifying the DNO n all........
JD6400
Mentor
Illegal supply's !
Australia
JD6400,
GLENNSPARK,
