Im not self employed so it's not about money....
I wouldn't personally live with vir cables or 3036 fuses. I guess it's an age thing? Vir cables must be at least 20/30 years old? I wouldn't drive a 20 year old car or use a 20 year old harness for rock climbing etc And with fuses it's far too easy for a non spark to change fuse wire for tin foil or copper strand etc there's some things electrically you shouldn't be able todo (again IMO)
I always knew us older types had it tough,not only have we survived these afflictions, we were sometimes the perpetrators of the installation of this pestilence
Now Bubonic plague or maybe Leprosy,that would get me thinking about not living,but 3036 fuses mmm I suspect not
Would you not be happy with 20 year old twin & earth then ??? Daz
- - - Updated - - -
Come to think of it, what's wrong with a 20 year old car?
Don't be scared of old things,i still rely on LOTS of old,even antique tools and equipment.I will give you an example of some i was glad to possess only today...my anvil,my 30 year old estwing,my 1937 house,oh,and me mum...
Antique?
There new.
These are antiques
- - - Updated - - -
twin and earths slightly different, most of that will comply with newer standards. my problem with the vir I've seen is most of the time it's at the very least 20 + years old but in reality it's more like 40/50+. The conduit that's imbedded in the ceiling/floor has usually rusted away so the earth is ****ey / non existent. Maybe my experience is warped because most of my experience with vir is when I'm rewiren it and I only see the bad conditioned and knackerred examples......
still dont like like it but :-p
About 20 years ago we put new MCC’s in a crushing plant. The original panels and cables were installed in the 40’s. Not wanting to re-cable over 300 motors and the control systems we sent samples to BASEC. (British Approvals Service for Cables)
The report that came back went along the lines of “you’ll probably get another 50 years out of them.”
All the samples we sent were strangely enough VIR. I think I’m more inclined to take their word for it than go by an unproved rule of thumb.
Each cable was tested before it was put back in to service. We only had a few fail, most of them down to mechanical damage at some point in the past.
All VIR cables will be over 50+ years old, you'll not find any in 20/30 year old installations!! If VIR cables haven't been subject abuse such as long periods of excessive loading or subjected to high localised heat sources, (such as incandescent lighting fixtures etc). Then you won't see much in the way of damage or deterioration in the insulation. You only saw rusted/corroded conduit when the black enamel conduit was used, instead of heavy duty galvanised conduit for embedded situations.
As i've told here before, when i rewired my parents house, virtually all the TRS T&E cables i removed were in such good condition, i used them to wire out the garage. One thing about rubber, it's not affected by the cold like PVC, so just the job for a cold precast concrete garage!! lol!!
I bet it's still working fine today too!! That cable will today be around 64 or more years old!! lol!!
The conduit was the only problem we had on the crushing plant. Some tunnels ran through solid rock, the water dripping on to the conduit and light fittings was alkaline. The VIR’s would be holding the conduit together.
I didn’t envy the two electricians mates that got lumbered with replacing everything. SWA with IP rated glands this time, I can’t remember what fittings they used.
Other plants where the product acted as a desiccant the VIR's, conduit and fittings were perfect.
More than could be said for the skin of the guys who worked in there, the company had to issue moisturiser.
I have seen similar,where the conduit had literally dissolved,leaving the cables showing intermittently along a run,under Lever Bros factory years ago. I was there to lay new floor to access tunnel that ran across the site,the concrete having also suffered the same fate...VIR was down but NOT out :icon11:
That's down to using the wrong means of containment for the environment it's being installed in.
Best example of that, which i have seen, is installing 3 1/2'' galvanised conduit below the ground slab in a soil that was literary laden with salts, sulphates, chlorides etc!! To cut a long story short, a sub-station building needed altering and extending, when they came across these electrical cables, that's all there was, ...cables, no actual conduit was evident, just a brown flaky substance was all that was left of the conduit.... From that day on, all metallic conduits/pipes etc, were laid in the slab itself or the screed!! I couldn't believe that anyone in their right mind would ever lay conduits, let alone metallic conduit ''under'' the slab in the first place!!
