Discuss Industrial USB 5 volt outlet in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello all,
I'm surprised how hard it is to find a USB outlet for industrial panels. I've found several small compact converters (I think aimed at vehicles) that give out the correct voltage and low cost but not DIN rail mounted. I was looking for a 24 VDC power supply with a USB (or 3) ports on them, any suggestions>
Andrew
Would a 13A socket with built-in USB be an option? Otherwise, can't you just get some panel mount B type outlets and a 5v DIN transformer??
Reply to Industrial USB 5 volt outlet in the Industrial Electricians' Talk area at ElectriciansForums.net
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
My customer read on many forums about people suffering to solve a problem with the above Land Rover with regards to a fault code known as P1260...
29K
