Hi all, just looking for ideas on how you typically install decorative garden lighting (say s/steel) - post type, into soft ground. Customers often provide B&Q type fittings with two/three base fixing holes which are a real pain. I previously had some great bases made up in plastic for a large job - diameter the same as the light base, with a centre rod which could be used to spike into the ground, as well as a threaded hole into which you could insert flexi conduit from the bottom. The light was just screwed onto the plastic base using s/s machine screws. Unfortunately, the company which made these up very cheaply is no longer around (maybe that's why!), but I'm now looking for time-saving tips for installing this type of lighting.Regards
