- Reaction score
- 322
Two years ago I installed some garden lighting, using u/g SWA to Wiska boxes, then 3-core 0.75mm rubber flex downleads from each LED fitting.
This week the 30mA RCBO kept tripping. I assumed a luminaire fault, or moisture in a Wiska box, but no. It was leakage across all three cores of one 10m length of rubber flex.
There was no visible puncture, and no moisture ingress. Out of curiosity, I kept cutting the length in half to isolate the fault, but every bit was the same! I ended up cutting the whole length into 1m pieces. All read about 0.4 megohm (The originally uncut length was about 0.2 meg).
This was new, modern cable. What's going on?
