G
gccs
Just had a 'heated' debate with an MEP contractor on the phone who is doing first fix for a job we're on. (We're doing the controls, av, security etc)
I told him to make sure that his team label all the cables as per my spec, every cable, each end!
He told me I was being ----, and I'm not sure if I should take that as in insult on a compliment. I've got over 500 sections of cable going in on this job, some for the network, some for controls comms, some AV some for DALI, CCTV, Security and so on...... I just want them all labelled...... (which I do on all of our jobs, even when we're doing 1st fix).
Your thoughts?
I am not an electrician, but to me that makes sense.
I wouldn't take being called ---- as a compliment but I suppose it depends on his tone! He may be miffed he has got to do something extra..
This is the 3rd MEP contractor on-site, the others have been booted off for being numpties. Perhaps next time the main contractor will use us for 1st fix too....
If he labels them then maybe a compliment but I would still say he has insulted you.
He couldn't understand the fact that some of the sensors and switches are wired with Cat7, on a star wired bus, so some devices have got 5 cables going to/from them off to other devices or back to the bus. I tried to tell him if a device or set of devices aren't working, I need to know which cable specifically to investigate. Similar with the DALI bus wiring for the lighting.
Given the conversation so far, I wouldn't trust that the cables were marked correctly.
If they don't undestand the reasons for marking, they're not going to be too bothered if it's correct or not.
I thought exactly that, so I think I'm going to send the local PM down for a day and test a big sample with a long lead.
Newbie so here my tu'penny worth. Been in enough server rooms late at night (previous career) to know when you find a well laid out and labeled cabinet you offer a silent "thank you" to whomever did that so you can fix the issue and go home. If you can't see the point of labels you should probably have a shovel- not snips- in your hand.
Imo a good electrician will always think of the next person that may need to follow them in the future.
As for labelling I must be ---- as well. Hell I even have a label on my labeller to say it's my labeller. :oops::oops::oops:
bananas on a labeller. i must tell brother.
Due to no cables being labelled and one of our sparks rushing in and not checking the cables he ended up taking out rather a large chunk of a data network for a couple of days.
I'm not saying who the customer was but if your internet was out up north all I can do is apologise to you and a couple of million other users...
