The drain pipe being conductive and internal to the property then means that it would also have to be able to introduce an earth potential (or other potential) into the property to be considered an extraneous conductive part. Because the conductive part goes outside and connects to a non conductive part, so long as the internal drain pipe does not go out underground as usual, then this should not be an extraneous conductive part and in accordance with the 18th edition statements would not require bonding as there is an insulating part before it reaches the earth.
If the drain pipe exits the property underground and then joins on to a clay pipe then earth potential could be introduced and the resistance to earth should be tested to classify if it is an extraneous conductive part or not.
