Hi there,
Happens to be a 2009 Combo 1.3 CDTi - 144k miles, regularly serviced - but its ABS related and that probably doesnt matter too much.
Please see graph1 (image) below - all 4 ABS sensors (2 front, 2 rear) behave pretty well upto around 25-30mph (note values are in KPH)
After approx 30mph though, the FRONT TWO sensors (Green and Blue lines) start giving less frequent and slightly-off results, causing the ABS light to come on - BUT, ABS itself still seems to be working when doing very-hard-brake tests. The rear sensors continue a smooth reading (Orange and Pink lines) without the bumps.
Ive replaced the front right ABS sensor and getting the same readings, so i dont think its directly a sensor problem. But Im struggling to believe the ABS module struggles to read the sensor feedback properly "at higher speeds" as that doesn't quite sound right either.
Has anyone experienced this behaviour before on any vehicle? / know the cause? is it basically just a whole new ABS module is required?
Thanks for any feedback!
Regards
magictr
Regards
magictr
