Discuss Is a new circuit board required? in the UK Electrical Forum area at ElectriciansForums.net
Kimjsy22
Hello, in preparation for renting out our home we have requested an Electrical Certificate and our electrician is doing a few minor tidy up jobs before the inspection takes place. He has just advised that we should get our circuit board replaced as it is in a plastic casing. The board is on the wall above a cloaks cupboard in the hallway near the front door. Apparently this is now seen as a fire hazard and if it caught fire it would obstruct exiting the building from the front door. However, we live in and upside down house which is a concrete build and there is an external door into the garden and street near the bedrooms. Does this make any difference. The house is about 20 years old and we have experienced no problems with our existing circuit board. We have had a new kitchen fitted recently and the wiring has been certified. Do we really need to change our circuit board now?
A plastic consumer unit would normally be given a C3 code, this means that it is recommended that you improve on the current situation.
A C3 code doesn't normally prevent the overall assessment of the installation from being satisfactory.
What you will be given after the inspection and testing has been done is an EICR, this is an electrical installation condition report. This does exactly what it says on the tin, it reports on the condition of the installation with the only possible overall outcomes of satisfactory for continued use or unsatisfactory for continued use.
If the outcome is unsatisfactory then there will be one or more things which have been coded as C1 or C2, these things will need to be addressed before the installation is considered safe.
Any items coded C3 are recommended safety improvements, you should carefully consider the merits of making these improvements.
Reply to Is a new circuit board required? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Just bought an old house (about 30-40 years old) with a separate shop building. I am in the process of replacing old fluorescent fixtures with...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
