Goody
I have this scenario: 2.5 mm SWA goes out from the CU and clamped direct on to the external wall into a water-tight plastic box (meant for this type of connection) and connected to the SWA cable coming from the garage – the connection is made using a JB. Does the REG objects using a JB inside that kind of box for external connections? Is there anything else available?
With the current arrangement I find it more protected against splash or leakage than using one of these from
