- Reaction score
- 0
Hi all, quick question, I have come across a 230V control circuit supplied from an Isolation Transformer. The controls are located within a metal clad enclosure near to local socket outlets and other accessories.
I have measured continuity between the metal casing of the controls enclosure and the main earthing system on the primary side and measured 10ohms?
Am I correct in thinking that there should be no continuity between associated metal parts on the secondary side of the install and the main earthing system? There should be no Earth bonding between the controls enclosure and the main earthing system if I am understanding the principles correctly?
There is no Earth point at the transformer.
Cheers all.
Cheers all.
