I want one meter to carry around with me, I have decided on one without frequency, as rarely need it, so want to measure current AC and DC, both total and difference, ohms, volts, and non-contact volts is a bonus, and down to 1 mA on current so I can test earth leakage, so settled on this
I have to admit the DC current is not that good, as it needs to be zeroed, and move the meter a little, and it changes value, so the 6 mA DC limit for type A RCD use is a bit hit and miss, but once in the 0.1 amp range, near enough. The AC amps works well, picture shows 8 mA earth leakage. It was cheap, think I paid £35, but as I look at Fluke and the like, I can't find much which can even do the job, never mind be better.
Clearly to measure earth leakage it has to be a clamp-on, meters without the clamp are non-starters, I know you can get add on clamps, but I want something easy to carry in the pocket, OK not calibrated, but I don't really need that accuracy.
For bench work I still have my AVO Mk8, but to carry around I want a meter which should it be smashed or stolen, has not cost me too much, and I find even measuring voltage the clamp does mean I have two hands free.
I have seen meter which hold one probe, which is a neat idea, and also some with frequency, but I still have my old meter which did have frequency, and never really used capacitance functions on any meter. I keep it with my RCD tester, and also have an insulation tester, but I don't take them everywhere, the clamp-on shown fits in my pocket nicely, no need to wear it around my neck like a badge of office.
Since I can test for current before I disconnect any wire, it means don't need a neon screwdriver in case any borrowed neutrals. Although I still do.
