• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Sam22
I'm needing a double plug socket in a new build property moving approx 1 ft to the right, then the wall making good (plastering, etc). Plug is on an external wall, behind plasterboard.
Approx quotes?
difficult to say without seeing the job,but a straight forward additional socket, close to existing should be no more than about £70. you to make good any plaster/decoration.
