• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
  • Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
S
Sam22
I'm needing a double plug socket in a new build property moving approx 1 ft to the right, then the wall making good (plastering, etc). Plug is on an external wall, behind plasterboard.
Approx quotes?
difficult to say without seeing the job,but a straight forward additional socket, close to existing should be no more than about £70. you to make good any plaster/decoration.
