Discuss joist span confusion in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I must run fp cable under floor perpendicular to Joists. i must drill holes in Joists and thread cable through. safe zone is 0.25 to 0.4 of span length. the Joists run as a continuous piece of wood from front wall to rear wall but are supported halfway by a wall underneath. should i therefore consider there to be a single long span giving two large drilling zones or instead two shorter spans measured from the intermediate supporting wall giving four smaller drill zones?
As Jason said mate.
Just bear in mind holes should be on "X" axis and no closer than 3 times the size of the hole you are drilling.
Reply to joist span confusion in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hello, i am just about to completely rewire a refurbished house. i have done the same to several houses in the distant past. i have just read...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hello, I'm about to start a complete house refurbishment, including rewiring and insulating between floors. As I understand it building regs...
I have unexplained equipment and diagram for three separate connected f81 connectors. Each f81 connector is connected to single receiver to single...
Hey folks, I had a couple of questions regarding running electrical cables in an attached garage. Any help is appreciated. #1. I am installing a...
5K
