not bad but struggle with some cable sheaths.
Yes absolutely brilliant! Before I bought mine I always used a ck electricians knife to strip cable. What a revolution, I really like it but they should make a bigger pair for 4-6mm!
Sy
They are brilliant but as Tel has said struggles with some outer sheathing.
Prysmian cables seem to be the main culprit, I think it's something to do with not using chalk in the manufacturing process.
And theres me liking Prysmian cables ! Ive noticed the chalk makes a huge difference .Not sure what other brand to use as Screwfix is super close to me and their cable prices not too bad.
I was very much of that opinion too @Pete999 it was the way I was taught to do it, but I couldn't believe how much faster & easier these made life, even on flex, cat 5 ect you can strip it with no damage to the insulation, fast!
I notice that Toolstation stock Pitacs and their price is currently slight lower than Screwfix - not sure if there's one close to you, but one big shed is the same as another and Pitacs seems to have a decent reputation.
If its nice to work with and easy to strip etc .I will buy it. The copper side of cable is not something i have heard to be a issue these days ????
and prysmian T/E is a nightmare if cold.
Its fine to work with and strip, got a load of it when toolstation price was way below every wholesaler in price
My experience of both cables is extremely limited but, as above, I found Pitacs easy to strip - easier than Prysmian, in fact.
I use a knipex one that slightly cuts the insulation of t+e. It's pretty good. Nor had it long and heard it wears out quick so I will have to see on that
