Discuss Junction boxes, other than Wiska in the Electrical Tools and Products area at ElectriciansForums.net
Fitzy
Hi guys
As the title says, other than Wiska junction boxes, what are the alternative junction boxes you use that are of equal quality and price?
Bit puzzled, if you want something that is of equal in function, price, and quality of a wiska box, why not use a wiska box ?
Sorry maybe I didn't word my question properly. the nearest suppliers to me (within 2 miles) are Screwfix & Toolstation and they don't stick Wiska, so just wanted to gain some knowledge of alternative junction boxes. ( nearest Wiska stockiest is a good drive away from me)
If you are near screwfix, they have lots of options...it all depends on what it is to be used for...
https://www.NoLinkingToThis/c/elect...sp=managedredirect-_-electrical-_-junctionbox
the Schneider ones are megga cheap, and perfectly ok for, say outside lighting, if fixed under soffits etc and for normal use in lofts...
if you want to bury outside, that's a different scene. I like the Wago weatherproof ones, but they are quite expensive
Aye, better choice and cheaper online too. For example my local wholesaler only gets the ones in with the screw connector strip included. You can get them without connectors for cheaper.
I think the full unit comes with the 5 way connector block and clip strip, this is for the smaller unit, always worth having if you are a jobbing sparks, I just mess around at home and have a few in my "stores"
If it’s for outdoor use I always make sure the boxes have exterior fixing holes.. No need to drill holes in the box and undermine it’s ip rating
Hi guys
I always buy these
32 Amp Weatherproof Junction Box - IP65 - https://www.tlc-direct.co.uk/Products/LB9045.html
I find them good quality, price is ok and they are easy to work with.
Screwfix sell them but they are a bit more so I just buy in bulk from TLC every now and then to avoid the delivery charge.
Ps.. Just noticed Richard's post in #16. I think they are the same ones.
Reply to Junction boxes, other than Wiska in the Electrical Tools and Products area at ElectriciansForums.net
Hi All. Anyone got experience/usage of using the Quickfix Junction Box, with the Wago 221 Connectors ? https://www.quickfixjb.co.uk/...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi all, with majority of new builds adopting loop at the switch for residential lighting circuits these days, am wondering if any one still...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
