H
Harrypops
Can I put a key switch on the ceiling for the non maintained emergency light illuninare. This is so that they are no wire trunking showing on the wall.
No. I would need a chair or ladder. the ceilings are 2.5 metres highCan they be accessed without access equipment.
Pmsl,No. I would need a chair or ladder. the ceilings are 2.5 metres high
Bad idea then.No. I would need a chair or ladder. the ceilings are 2.5 metres high
What is put the switch 1.9 or 2.0 metres high on the wall. I don't like to see the ugly trunking. Thanks WestwardCan they be accessed without access equipment.
If you need access equipment for routine testing it is a bad idea I regularly note this in reports.What is put the switch 1.9 or 2.0 metres high on the wall. I don't like to see the ugly trunking. Thanks Westward
studded wall, fish it. solid, wall chase it. sssimppless.What is put the switch 1.9 or 2.0 metres high on the wall. I don't like to see the ugly trunking. Thanks Westward
Thank you I found some self testing ones for£20 each on AmazonSome emergency light fittings have the test switch on the fitting… but of course, at that height, it’s not very handy either.
Did I see that some come with a self-test facility?
Another question. Does the light have to be 30cm from the light, like a heat alarmBad idea then.
Em….Another question. Does the light have to be 30cm from the light, like a heat alarm
