Dishman
Hi,
I am looking to install these lights from IKEA in a kitchen under the wall cupboards
NON LED worktop lighting - IKEA
One would be near the sink and one directly above the hob (steam). Is it safe to install these in these locations as the lights are mains powered (psu converting to 12v dc inside). Just worried about the power switch as this is before the psu but only on the live or neutral (depending on which way the 2 pin plug is inserted - I am in Spain).
This will be protected by the main 30 mili amp RCD trip.
Any thoughts? I am obviously not a trained electrician (even though my father was an electrical designer (TVs etc)), but its impossible to find a genuine electrician where I am, so any links to relevant info would be very welcome.
OK, few things here:
The vast majority of the proper sparks on here are UK based, therefore we take BS7671:2008(2011) ['the regs'] as our guiding principal and bible. BS7671 does not actually include kitchens as a 'special location', therefore there are no hard and fast recommendations. Were you in the UK then there ARE some regulations to kitchens which apply under Part P of the Building Regulations.
What your legal position is in Gran Canaria I've no idea!
As far as these lights are concerned, they're designed and marketed for this environment, and we fit them and many similar types all over the UK to no harm. Just don't try and rely on the self adhesive strips on them - put a screw in!
Hi Rockingit,
I am not worried about the regulations TBH, I am more worried about safety. i don´t want anyone getting a shock. I know in the UK that as these are being fitted with a mains plug they are classed as appliances and are exempt.
These lights are rated for IP21, but that only covers static electricity.
The case is completely plastic, I am just worried about steam getting in or people with wet hands. I have looked inside and the PSU is in a seperate plastic housing so a lot of water would have to get in there to reach it. Obviously with the unit being upside down gravity should force water out (though steam could coat everything with water). The switch on the unit is on the live or neutral dependant on which way round the two pin plug is placed. I did think of coating the PSU in silicone, but that could cause other problems such as over heating. Also I could drown the internals in WD40.
Just want to know the risk of shocks and how to minimise them.
Hi Rockingit,
We have regulations to keep things safe.
Yes I understand that, but with all laws and regulations there are loopholes. The loophole as I explained in my question was the fact that as it was connected by a plug made it an appliance and therefore exempt, it does not mean it is safe!
i would worry about product fit for location,above a cooker, steam could drop it like a fly.. and you could end up eating it if you wernt keeping an eye on your paella. if you worried about safety you have to think where to mount accesories and decide as competant person weather your in fiji or samoa or northern ireland.
For what it's worth: I doubt very much that you'll run a real risk of electrocution - the units are built to be fitted where they are and IKEA will not be selling something knowingly unfit for service, however I do think that the units might not last that long!
I also doubt the IP21 rating - a paper bag rates higher than that!! In reality, it needs to be good for occasional steam and damp environment - if you go to the theory sub forum I think there's a sticky on IP codes - take a look and form your own judgement. IP54 would be the starting point for a suitable fixture to do this job.
Thanks Rockingit. Well as its from IKEA its a given it wont last long. There are no wriiten instructions with the lights (as with all IKEA stuff), except to say that the cord is not replacable and unit must be disposed of if cable gets damaged. Also all the IKEA pictures show the lights under units away from sinks or hobs. They cover themselves nicely!
Heat would not been a problem, plus I would have fixed with screws. Think I will err on the side of caution and fit battery units.
