B
brodders97
Hi all,
I’m hoping you can shed some light on a problem I found. Please be gentle, I’m an industrial spark, not a domestic spark.
I’ve been asked to look at a family members electrics as they are renovating a room. A cowboy spark has been in and messed the job up. I was asked to come in and sort it out, my first plan of attack was an EICR on the property. Looking at his work (pictured as he left it) probably a waste of time.
Anyway, I was performing some tests on a non rcd protected board with everything unplugged etc. The circuits tested ok except the ring final, the circuit he has been working on. I found 11 Ohms between L-N from the board. Some sockets were reverse polarity.
When I tested between L-N in the room he had been on, the reading was much lower at 1 Ohm, so he’s done something here.
What I don’t understand is, if there was a short circuit between L-N, why has the MCB not tripped?
They are wanting a board protected by an RCD but obviously that can’t happen until this is sorted. What would your plan of attack be to sort it?
Thanks all
Thanks all
