Discuss Landlords certificate Earth bond to Gas in the Central Heating Systems area at ElectriciansForums.net
S
Specialist
Hi Guys: Had a call from an old customer, he's bought a flat to rent out & had a Gas fitter in to do safety checks & issue a Landlords certificate. Gas fitter did whatever checks he had to but won't issue the cert as there's apparently no Earth bond to the gas intake.
The customer was then told by another Gas fitter, that he should have been given the certificate as Earth bonding to the gas is only an optional check, not compulsory.
Obviously he has to have the bonding done, but I was just wondering if bonding is an optional check ?
I've always wondered what the hell its got to do with a gas fitter?
He probably does right addressing the fact that no Earth bond exists at the meter and informing the relevant people but what's it got to do with a gas service?
Unless there's a reason someone can give me?
I had the exact same job and reason to do it, this last Friday. Landlord was alerted to it by the gas check as he's about to rent the place out - sweet little job but outside was on a busy road. Minor works after continuity test, to him to make that CP12 that Lee noted - ready to rent.
I did a cursory zs check recently.... To find the house wasn't earthed (1955 build).
2 years ago they had a new boiler fitted ... No bonding either.... The gas man must have noticed the lack of bonding as the boiler, cu and incoming gas were with 4 feet!
Spoke to the gas fitter today that checked this flat, apparently he didn't just refuse the certificate because of the Earth bond. He classified the boiler as unsafe and poorly installed as well, hence the refusal.
Anyway I was asked to go over & have a look at the electrics with a view to doing the gas bond, went over & looked then walked out the door.
No earth bond to gas or water, Socket outlet in the bathroom, CU been changed in the last month but old RCD left in place apparently as an isolator, CU plastic with single RCD so not compliant.
No certification of any sort given, apparently his builders sparky changed the CU & said he didn't need it.
Have informed him of what I've seen, now it's down to him to get it sorted.
Going to be pernickety here - there is no such thing as an earth bond. Earthing and bonding are different things which serve different purposes.
The gas safety (installation and use) regulations are law and therefore free for anyone to view online at legislation.gov.uk
As far as I know the only part of that which relates to installed bonding is regulation 18(2)
"(2) Any person who connects any installation pipework to a primary meter shall, in any case where electrical equipotential bonding may be necessary, inform the responsible person that such bonding should be carried out by a competent person. "
There is also a regulation requiring that temporary bonding be fitted when necessary to maintain continuity while work is being carried out.
That relates only to when a pipe is cut or fitting dismantled .
A temporay strap is used across the break regardless of whether the installation is bonded in case there's a fault current in the pipework which coud lead to a spark at the break in the pipe.
Using one of these;
Rothenberger Continuity Bond With Crocodile Clips - http://www.NoLinkingToThis/p/rothenberger-continuity-bond-with-crocodile-clips/97463?_requestid=36366
Reply to Landlords certificate Earth bond to Gas in the Central Heating Systems area at ElectriciansForums.net
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi, Our cooker is LPG, fitted on the inside of an outside wall if that makes sense. The gas pipe runs internally then through the wall to the...
6K
Went to fix a simple issue for someone . Then realised they where tenants and asked if they had a copy of the EICR ....NOPE . Turns out no Gas...
Hello. Non-electrician here. Failed an EICR yesterday as the electrician graded my consumer unit C2. Why C2 and not C3? He didn't say (and still...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
