I’ve been thinking about the speed of wiring lighting in a domestic installs.
LCM boxes are the norm in Commercial installations however when it comes to domestic they are never used.
Dali and low voltage switching a side, would anyone consider using LCMs when wiring multiple lights in one room?
Can't see many domestic installs justifying them. Then where to put it - attic upstairs, but where for downstairs ?
Most would just stuff a million wires in the back of a shallow switch back-box for a fraction of the cost.
Yes upstairs would be the loft, downstairs it would be challenging especially I new builds with limited space.
However, what about this scenario -
if there was unit say that had a switch wire flex long enough to get to the switch for a 230v supply. The unit was sealed so no need for maintenance and there were pre made leads that would go from outputs to numerous lights, would you consider it for speed on installs?
I can imagine some would, I wouldn't because it would be something else inaccessible if it did go wrong. But there's still the matter of whether it costs more - given that newbuilds seem to be designed on the basis of "where can we shave a halfpenny off the cost ?".
For my own house, I'm considering DALI - need to learn something about it. Specifically, I want some functions that can be computer driven (probably OpenHAB) - but work on a local controller so not reliant on the computer for the basics.
Yes the integration of Dali in domestic at present is for a typically high end installs but with advances in technology surely the cost of these installs will start to reduce.
I work mainly on commercial installs and still have to explain why just ‘dimming a room or office with a rotary dimmer isn’t advisable. However the price of installing Dali systems usually isn’t in the clients budget.
