Discuss leaving lights when moving in the Australia area at ElectriciansForums.net
S
SPARTYKUS
Hello
...when someone moves, are they now legally or contractually obliged to leave lights ... as in you can't nip off with the light fittings and leave none, right?
....so....can anyone tell me, does this apply to wall lights, or could you leave them capped off.
I guess what I am asking is this a rule for safety reasons, as in being able to see at night, in which case, if its a room with the main light replaced with a pendant instead of the crystal chandelier, then the wall lights can be left .....?
S
I think it's usually specified what's included and what's not, eg carpets and curtains, so I would imagine light fittings would be the same - as you say, you probably wouldn't leave or expect to inherit an antique crystal chandelier, but I would expect to buy a property with at least a battenholder in each room, ie a useable installation.
As long as the cable from the wall lights is terminated properly not just taped up with insulation tape and shoved in the wall then there should be no problem. I install architrave boxes with wall lights which I can put an architrave blank plate over when not in use.
Reply to leaving lights when moving in the Australia area at ElectriciansForums.net
Plasterer has been in this week and after leaving today, he left the light on in the room. I went to the room to turn the light off and saw the...
4K
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
Hello All Strange question for you, I know you don’t have crystal balls :) but can anyone give me any clue on the following… I have mid eighties...
I moved into a house where the owner left an air compressor. He started wiring it before he left, said it works but needs wiring finished. It has...
