Discuss LED conversion '99 Lincoln in the DIY Electrical Advice area at ElectriciansForums.net
I am not a professional...I am a DIY senior. I want to convert my '99 Lincoln Continental from the OEM halogens to LEDs. I previously converted my '05 Ford van by swapping out the flasher control relay and all LEDs worked perfectly. Since the Lincoln flasher unit is buried under the dash, I am trying to make the conversion using LED load resistors on all lines for the turn signals wires, but, even with resistors installed, I am getting hyper-flash. At first the blinkers worked until the parking lights/headlignts were turned on. Then they went to hyper-flash. I have tried using double resistors, using 6 Ohm and then 8 Ohm resistors, and even adding a resistor diode to the non-flashing wire to my turn signals. I also tried a plug-and-play ready made wiring connector that used a resistor on both the non-blinking and blinking wires. All of these attempts have failed. In fact, now I even have hyper-flash when the parking lights/headlights are not on!
I finally bit the bullet and dismantled the dash and retrieved the flasher relay but I have not been able to find an electronic replacement. So, can anyone diagnose my problem and how best to correct it? Help, please.
Reply to LED conversion '99 Lincoln in the DIY Electrical Advice area at ElectriciansForums.net
Good morning guys, I bought this neon sign for my cinema room to put above my arcade machines. I have the cinema controlled by Google voice...
I am currently making a scaled model display that uses 16 LED in a series and I would like to wire it up to be on one switch, so I need a single...
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
