Saying that Tel - obviously having a brain fart moment, as a GU10 LED could go in either way so polarity not an issue there. 12v DC, it would be I guess. Thanks
Hi - that was me suggested that. I was wrong, it will make no difference as the LED and halogen lamps you have are 230V AC units and are not polarity sensitive. @telectrix has the answer, I think.... If you say the wires might need swapping which would then supposedly mean the 2 outer light works but not the middle, then how do I get all 3 working? I'm fairly sure the wires in and out of the terminal block are correctly wired but didn't know that a normal halogen will work if the L & N are mixed up...
