M
michael_brooke
Hi all
Can led spot lights be wired the same as a standard spot light or do they have to be wired in series and if so do they need a driver im a little confused
The led downlights ive installed come with there own drivers the wiring is the same, so its just like putting in a normal downlight, the same goes for all led's 230v supply into a driver as they run on DC voltage.
depends on the lamps. if they are GU10s, 240v. then just fit as you would a halogen. 12V LEDs require a DRIVER.
LEDs wired in series are connected end to end (the negative electrode of the first LED connects to the positive electrode of the second LED and the negative electrode of the second LED connects to the positive electrode of the third LED and so on and so on...). The main advantage of wiring things in series is that it distributes the total voltage of the power source between all of the LEDs.
all depends on the voltage requirement of each led and the applied voltage.
So all 12v led's have to use a driver and be wired in series, can they not be wired in parallel
all depends on the LEDs. if you have 6 x 2V wire in series. if they reqiure 12V then wire 1 LED to 1 driver.
You still need to wire them in series if you run more than one off a driver, the manufactuer will be able to tell you how many that specific driver will be able to run. If you wire them like normal they will be alot dimmer
Ok just 1 more question how is it ur able to replace halogen lamps for led lamps in a halogen downlight surely they need a driver
if they are 240V GU10s, then the driver is incorporated in the lamp.
You wire them in series if your running multiple lights off one driver
Thats because the driver is a constant current source which the LED needs, so when in series the LEDs get the same current, although the voltage at the driver terminals may increase with more leds in the circuit.
This is probably 'old' technology now as most LED downlights are 230V coming with their own integrated drivers.
