Can't agree with you this time Tel; once we start picking and choosing which parts of the Regs to ignore, we're on a dangerous path. I agree the risk is small and the proposed solution is a quick fix, but I wouldn't adopt it. :aureola:
if it's only accessible with a key or a tool, it's outside of zones. FCU would be preferable, i agree. but there's no reg. that says a 1363 socket outlet should not go under a bath. as for leaks, well, you could fit it in the airing cupboard and the attic tank or any water pipe could leak onto it.
Would have to go with Laurie on this one -- regardless of zones no socket within 3m of the bath/shower.
Must confess, until very recently I thought it was ok to put a socket outlet under the bath (viz area not accessible without a key/tool) too, but have since been convinced that the "no socket outlet within 3m" takes precedence. Other opinions are available!
What about if you put the socket in a "dri box" the type used outdoors to house extension leads etc then if there was a leak it would at least offer some protection.
Surely if transformer/driver is suitable for locating in under bath ie ipx4 or above than that should be ok. The equipment can be fed from a sfused connection unit outside of bathroom. instead of placing socket under bath cut plug off and use a weather proof enclosure with appropriate stuffing glands to terminate primary side and another enclosure for secondary side.
Also as led lts are to be installed on the face of bath panel I.e. zone 1 ensure they are also are suitable for installation in that zone that is ip rating and pelv.Also holes drilled in panel are sealed after lts are installed
Obviously all ccts protected by rcds/rcbos .
As said earlier area under bath is not in zones if panel has to be removed by tools.
Mains voltage is allowed under bath as long as suitable for area such as shower pumps and jacuzzi etc providing not in zone.
Sockets not under baths is not against regs as no one is going to get a tool undo panel remove transformer socket and plug in hairdyer etc. Personally I wouldn't leave socket under but it is not against regs under condition above.
If you are able to make a 230/240 socket under the bath, you will also be able to make an alternative socket or wiring under there.
put your transformer elsewhere, and use low voltage to the bathroom.
make sure your cables can handle the Amps needed for the lights as low voltage is higher amps, so more loss on the cables.
I would keep high voltages away from the bathroom as much as possible.
Ray
If you absolutely must have a socket under there (and I don't really agree with it), then at least make it an IP rated external-grade one, such as an MK Masterseal.
This is the problem with the electrical game there is never a straight forward answer. The socket will get installed under the bath, thanks for your input.
m1 I have installed loads under bath in my time, I am happier doing this than installing an electric shower being sprayed with water any day of the week
I'm with stroppy on this. if there must be a socket under there, at least make sure it's IP66 or the likes
blimey people !
with the regs regarding no socket within 3m ...
i have a socket on my landing that is less than 3 meters away from my bath, does that now not comply !??!
What's to discuss, the regs state a socket is permitted under the bath with access via a tool.it's not classed as a zone and it should have rcd protection. Why make things way more complicated than it needs to be
