Discuss LED Tape fault help in the UK Electrical Forum area at ElectriciansForums.net
One series string of LEDs is dead. There is a break either in one of the copper tracks, or a solder joint, or perhaps one of the current limiting resistors is cracked. Water ingress / impact damage / too much flexing during installation would be likely causes, or it could just be a random failure.
Reply to LED Tape fault help in the UK Electrical Forum area at ElectriciansForums.net
Hello, Does anyone know of a Driver for led tape that can adjust the brightness on the driver itself by turning a screw etc ? Just need...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, someone has ordered Steel Tape Armoured cable instead of SWA. Can I use this armour as a CPC the same as SWA or not and if so is there a table...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
