Discuss LED tube from old light in the UK Electrical Forum area at ElectriciansForums.net
HI all, have the following light i asked someone to get me when ripping out a room,
looks like there was a emergency pack and capacitor etc in a box above the ceiling.
so want to Put a LED tube in the fitting but cant seem to find the right one
here are some piccy's, tube length is 114mm
can anyone send a link,
thanks
Grand
that lamp didnt work, i assume it had to have the guts all in it, mine just had cables direct to the lamp holder.
[automerge]1572019512[/automerge]
ok stuck again, the Light fitting has no ballast or starter, the cables you see in the picture go direct to the tube end caps that hold the lamp in, cant seem to find the right lamp if can be done that is
length is 1400 if you havent realised it was a typo,lol
Is T16 and T5 the same lamp holder?
[automerge]1572082329[/automerge]
Did the lamp physically fit?
i assume the ballast starter and emergency gear was in a separate box up on a shelf , certain wires came from it to the light fitting,i only saw these in the corner of the room and was asked if i wanted them, thought i could make use as they seem to have a high build quality feeling them.
Reply to LED tube from old light in the UK Electrical Forum area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hey all, So this is probably a quick question. I have some under-cupboard kitchen light tubes that are old and have clearly blown at some point...
I installed these round light fixtures in my office 23 years ago. After a few years the circular flourescent tubes went out and I replaced them...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
