Discuss Light fittings in the Australia area at ElectriciansForums.net
W
Warriors2008
Hi all,
New to the forum and this may be a simple question for someone but here goes. I have two lightfittings in my kitchen, one of which is permenantly live I.e the lamp is lit all the time. I measured the voltage and it is Reading 293volts on the loop and 49 volts on the switch side when switch is off! Any ideas guys? Thanks in advance.
Reply to Light fittings in the Australia area at ElectriciansForums.net
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
