B
brodders97
Hi all,
I’ve got a question about an issue I’m having.
During a kitchen renovation we’ve decided to have open doors fitted to the patio and as a result I’ve fitted 2 way lighting to the kitchen spots.
I’ve also broken in to the permanent feed and neutral going to the spots first and run an outside light over the doors.
When this light is switched on it comes on very dim, and it also dims the lounge light.
I can’t work it out as the cable I broke in to was definitely the permanent live and I brought that down to a switch then back up to the outside light. Voltage is 230v one side of the switch and then 230v back at the light when switched
I swapped the outside flood too but still the same issue
I’ve checked for loose cables
It sounds like the cable that you think is neutral is actually a switch wire for the lounge light.
Reactions: DPG
Thanks for the reply, it definitely isn’t the switched live for the lounge light. I can see that which is completely out the way
Email
Time zone
Last seen
Lights going dim when switched
Lighting Forum
brodders97,
brodders97,
