Discuss Loft light? in the Australia area at ElectriciansForums.net
S
SparkSmog
Im going to install a light in my loft, anyone got any reccomendations of which light fitting to use? Im assuming id just be able to take t&e off the upstairs lighting circuit and run it to it?
I usually do industrial work so not to sure about things like this so any help is appreciated
I cant see a Problem with it (not saying there arnt any). As long as its clipped and not strung across i think it will be fine, Maybe stick it on RCD or RCBO just to cover ya self! Although if its in surfice i dont think the regs require it.
I repaired mine - previous owner had taken power from a ceiling rose but in the process had broken the fitting so replaced that and took the power via a junction box instead, clipped cable to joists above insulation and put in a cord pull switch that hangs close to loft entrance so can put the light on the moment you open the hatch.
I would take the supply to a switch( pull cord or standard )
You can then use a switch with a neon
It helps rule out having a nagging feeling a few weeks later that you left it on
Fluoresent light or 2 or more every time for me
Hi Sparksmog
I would check first to see if the lighting circuit has been wired in 2 or 3 plate, as 2 plate would mean you will have to get your feed elsewhere..
Regards
Reply to Loft light? in the Australia area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
