Discuss Looking for advice please. in the UK Electrical Forum area at ElectriciansForums.net
B
Balfin
Hi, I’m not sure this post is really relevant here, but I’m looking for some advice about some electrical work that was undertaken at my home.
For background, I live in a converted cottage in Scotland which was to be a renovation job for my husband and I. The cottage is old stone (old) base with a 1970 extension to add a kitchen at back and an upper floor – all breeze block. The old stone part has panels and plasterboard on the inside the 1970 part not so.
Sadly my husband was diagnosed with MND shortly before Christmas, so what was to be renovation work has quickly turned into house adaption + decorating.
Naturally I thought it wise to start with the electrics – as an old house there are few (12 or so) sockets and we need a lot to cope with all the medical equipment going in for my husband.. The fuse box had already been replaced (6 months before). Being in something of a hurry I engaged a local electrician who had a shop on the high street and although I though his quote a little high, I went for it, believing that he had a reputation to upkeep and that he would do a good job.
He inspected the job and sent a quote – based on a fixed rate per socket (£60). I made it very clear that the house was to be renovated and that I was not concerned about the walls / skirting as these would all be getting replatsred/replaced soon in any case. I made it very clear that I wanted all wires raggled into the walls or under skirting – ie completely concealed.
Two electricians worked for two days on the job – at the end of the first day they had added sockets downstairs – run behind plaster – all good. Although the sockets themselves were raised (10cm) rather than flush with the wall.
Day two was upstairs. I returned to find they has run all the wires on top of the wall with large, square plastic insulating run all around the rooms and landing. All the socket units were sitting on top of wall – in short it looked an absolute mess with plastic running everywhere. It looked like the cheapest job possible had been done. Moreover, as space is an issue this is causing a problem for my husband as he has hoists etc which need to sit flush with the wall and have a free run – the socket etc are causing a problem.
I went to see the owner of the company – he told me there was no choice as the walls were breezeblock. He was very patronising and I left his shop very upset.
When I received his bill, he had charged for 2 days labour @£500 per day (£250 each electrician) + all materials, rather than the unit price he had quoted. The bill was £1500 double the quote
All in all a bit of a disaster. I am looking for some advice.
Is it true that wires can’t be run into breezeblock walls? Is there a better option? In light of what was scoped for the work – what would a good electrician have done and roughly how much should this have cost?
Is it worth trying to get this company to rectify the work? Or better to cut my losses and engage a new electrician? Given the electrics/wiring is in place - would the job of concealing the wires be more of a builder/plasterer job?
Sorry for all the questions, I would like to feel informed before I revisit the company or raise the issue again. If I wanted to make a complaint or refuse to pay the full bill – is there an industry advice centre that can advise? Would it be appropriate to make a complaint if I don’t get a satisfactory result.
My apologies for such a long post – many thanks for reading this far. I would be truly grateful for any advice that anyone could offer.
Thank you.
Thank you.
Do the rooms where you had sockets installed have a traditional wooden floor? i,e, floor boards and joists.
If the answer to that question is yes, were/are you at all concerned about floor boards getting damaged? Even if you had a solid floor there is no reason why most of the wiring could not be chased into the breeze blocks (Channeled in) Were you supplied with any completion certificates after the install?
The price you quoted is high for an Electrician day rate, if you feel you have been scammed then try contacting trading standards. May be one of the members up your way could take a look at the work, it sounds to me that this Electrician has taken advantage of you predicament and taken you for a ride.
How many sockets did they wire in total? Because if he quoted £60 per socket(going rate as thats how much i charge) then it should be £60 times x amount of sockets.
Thats all you should pay.If you have floorboards upstairs then the wires should be run under the floor and up to each socket.The sockets should be flush to the plaster. Trunking is only used if there is no other way possible that the wires can be run in or if the customer doesn't want any damage doing.
I wouldn't pay him any money just yet.Can you post some photos of the work done and we can tell you if it's been done correctly.?
Do you have written confirmation of the quotation, being invoiced for twice the price of the original quotation doesn't seem quite right. What did the original quote cover?
A company charging £250 per day for an electrician, is not unusual. Have they done more work than originally quoted for.
You may have to negotiate the invoice, as the work has not been completed or completed to your satisfaction.
Building regulations differ in Scotland, to where I live in England. But it is quite usual to chase or channel breeze block in England, unless there's some structural reason.
It may be you should obtain some legal advice, before paying your bill.
as above. i can seee no reason whatsoever of surface mounting of cables in trunking and surface mounted sockets. i'd get another electrician to assess the work before parting with any monies to the clowns who did the work. and make sure you have an electrical installation certificate from them anyway.
Reply to Looking for advice please. in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
