Do you think the following connector is what I need? But looks like I’d have to cut off the current connector to the lights?!I was thinking the same... and I'm sure I've seen this used on similar light systems before...
Discuss Looking for old transformer in the DIY Electrical Advice area at ElectriciansForums.net
Thank you. It worked! And all fixed. Really appreciate the input.I was thinking the same... and I'm sure I've seen this used on similar light systems before...
Thank you. I got it working!It looks like the light string is the standard 2 pin that’s quite common now, with a D shape so it only fits one way. Roughly 10mm diameter, 6mm between pins?
The one I linked to on eBay has the same transformer number, but the socket is a round pin and a flat wide pin. Like a 70’s hi fi speaker socket.
Reply to Looking for old transformer in the DIY Electrical Advice area at ElectriciansForums.net
