Hi
Just bought this 1960s house, will be doing full rewire. Incoming supply splits and goes through hole in garage to next door. This is a looped supply?
From what I've read this can restrict us getting an electric car charger in future, that I can speak to the dno about unlooping.
Electrician said the earth cable clamp (coming from next door), clamping on to the mains at the bottom, was loose. Is that a dno issue?
How safe is this setup, sharing next door via a hole in the wall? I believe they are on old style fuses like this with no rcds. If anything were to blow or fire on their old electrics, would it quickly spread through here?
I don't want to annoy the neighbours by having the driveway dug up, but I also want to be safe.
On the full rewire, does this old bit of backboard have to stay? Or is it fine?
Thanks. So it's not a looped connection?
"What happens if you share an electricity supply with another property? When two properties share a single electricity service cabled, this is a ‘looped service’. These are often found in terraced or semi-detached houses. The service will enter into a property via premises 1 and be looped into premises 2. Everything else is the same as an overhead or underground connection."
Either way, if it is a single feed coming into our garage, going to both properties, what are the risks? What load can be put through here? What if we want a car charger? What if the neighbour circuits blow due to having 1960s circuits that haven't been updated?
Shared supply will be treated same as looped from dno perspective.
If looking for an ev charger in the future they will unloop for free, which could involve major groundworks, but at least you aint paying for it!
If you know the rating of the fuse then via 2 ct clamps you can still monitor the loads and group them via the zappi group monitor function
Have you actually cheked your neighbours to see if they have a meter? have seen cases and images online before of people having an unmetered supply... werent very happy when neighbours got it disconnected!
Should also say that if the dno become aware of this they may decide to enforce the remedial works... Had a situation in Bath where by one neighbour wanted an ev charger but was looped and fed next door. the neighbour wouldnt give permission and kicked up right fuss. was fuming when his power was off for a few hours as in the end they did all the remedial on my customers side and left the awkward one with a 60a supply and the old cables but my customer got a nice 100A supply with PME, my customer agreed to old cutout remaining in place but unused alongside a new one.
Long story short your neighbour doesnt have much say in the matter! dno can force the remedial work on them if they want, they have quite wide ranging powers.
Its a shared supply off the same cutout fuse, eg if the supply is fused at 100A, then that 100A is shared between the 2 property's. The other property will have a cutout fuse (maybe 60A) metering equipment etc.
My advice would be to speak to your DNO regarding EV charging in the pipe line, could be a cost involved to split the shared service? they will advice or maybe free of charge.
Hi
Yes, with them tagged off the outgoing side of your cutout fuse you probably want ukpn out to sort if your wanting a car charger etc, and yes their earth on that clamp doesnt look amazing either
UK
Looped supply through garage? Look ok?
chriso,
grumpyjohn01,
