L
Lucien Nunes
Damp here this morning, and the insulation resistance on a piece of workshop equipment seemed a bit low. I could influence the reading by pressing my hands against the outside of one of its controls. That, and the fact it is getting a bit stiff to operate, show that it's time for this control to be stripped down and cleaned. Metal deposits and dirt build up inside over the years and cause leakage.
The main core of the thing consists of 36 parts threaded onto a shaft. I slide them onto a long screwdriver to preserve their order and orientation as I take them off. Then as I clean each one I put it back onto the shaft.
What equipment is it part of? The maker's name will be familiar but the equipment itself probably not so much. A couple of people here will get it in one. Give the others a chance.
When you said about the items on the shaft I was thinking some sort of cam operated programmer. But the photo doesn't show one.
Definite similarities though. That pic shows some of the conductive build-up on a moving part. It rotates around this part:
Some sort of slip ring then? A rotating table?
Nine sliprings, if you want to call them that.
So transferring power to a rotating part. Nine rings to cope with the amount of current needed to be transferred?
Nine because there are nine separately movable subassemblies. Hub, fixed contact (slipring), rotor and moving contact.
Tricky. Is it a machine tool of some sort, or some obscure test rig?
Is it the Enigma Machine??
Also lots of similarities.
Section 9's wheel and moving contact cleaned
Struggling. If nobody guesses can we have another clue?
Inserting the contact rods.
Still looks like a cam programmer to me.
Some form of calculating machine.
Operated manually. Nine 1-pole 10-way switches in a matrix. Dial each of the nine wheels to a setting from 0-9.
Bear in mind that it is a piece of equipment that I actually need to use. I don't have a substitute. And that insulation resistance is important.
So thats how lucien types up his threads?
I did make a ZX81 input device consisting of three dials and two buttons, when my membrane keyboard gave out in the middle of a project.
Detent springs adjusted and shaft nuts locked with lacquer
The ZX81 keyboard wasn't the finest piece of engineering ever! Had that ribbon cable in and out many times....
Reactions: DPG
Resistance decade box?
Or something related to valve testing? Maybe to set the appropriate voltage to one of the valve electrodes?
If you show me the completed picture, then explain exactly what this machine does.... I still don't believe I would get it.
On something else at the moment - the quest for M8 turnbuckles that are a few mm shorter than the DIN standard size. Looking at some pics online I got an idea that versions with locking nuts had shorter bodies so I ordered samples, but the bodies are the same size. The eye screws are threaded further to the end which is useful though.
I'll.put this back together after lunch and a bit of admin.
And then I will do some 026 540 310
KT66 ?
  • Winner
Reactions: Lucien Nunes
Reactions: timhoward
Bad picture, best I could find online.
Take it you have a vintage AVO panel tester?
Did I get it in post #21 then?
OK yes joint win, didn't see your edit, when I looked at that post it only mentioned the resistance decade box.
Reactions: DPG
Thanks flip. Made my brain hurt!
Yes, it occurred to me afterwards. Luckily well within the edit window.
My next guess was going to be some sort of capacitance or inductance measuring bridge.
I wouldn't have got it without the valve specification clue:
KT66
026 540 310 A100V, S60V, MAV6 HTR6
It's been many years, anode, screen, ma/v, heater I think?
Reactions: DPG
KT66
Didn't cotton on to that! Nice one
Those settings are not for the VCM though. The 2-panel tester is a simple zero-bias tester that is not well suited to later high-gain power bottles and has to test them at low voltages. The VCM operates the valve under realistic operating conditions and can be used to plot curves. A:250, G2:250, G1: -15V. Then you are looking for Ia=65mA and gm=6.3mA/V.
Those still not with us, the rotary switch assembly I was servicing, called a 'roller switch', allows each 'test lead' of the instrument circuit to be connected to any pin of the valveholder (=socket). There were thousands of different types of valves on dozens of different types of bases, with the same pin being used for different functions on different valves. I..e for a KT66, in addition to dialling in the anode voltage as 250V, you also have to dial in that the anode is on pin 3. and the same for all the other electrodes.
Different testers had different ways of doing this but the AVO roller switch is generally considered one of the best and slickest. The settings are given in the AVO data book but if you know the valve pinout you can work them out on the fly.
For a reminder of the KT66, one of Britain's best-loved audio output bottles, see:
or download the dataheet here:
I wouldn't have got it without the valve specification clue: KT66
At that point, I was wondering was this some newer Kewtech MFT model I'd not heard of . . . . .
I'm convinced now. yous was born on Mars and come here to confuse us all into abject surrender.
Low insulation puzzle: what's this?
Lucien Nunes,
Lucien Nunes,
