Please give context when posting stuff like that! That's a deliberate attempt by young adult riders to abuse a childrens' ride and it's mistitled, so it does seem to have been done for shock effect. I am not sure why the car came adrift, that is concerning, but it's also a bit off-topic here because I want to talk about the electrics of British travelling fairs mainly, and that's a mechanical issue with a ride in Sweden.
The challenge that fairs have to deal with is that when anything goes wrong it generates huge publicity, often because it involves families with children etc. Every accident becomes nearly national news in a way that similar accidents at home do not. The HSE discovered a few years back, by searching records over many years, that people are 12 times more likely to have an accident travelling to and from the fair, than at the fair itself. And that even takes in the 'deliberate accidents' where nutters try to climb out of their ride seats or defeat the safety interlocks etc. If you count only genuine accidents where something is wrong with the ride structure etc, then the ratio is even higher. Accidents caused by mechanical failure of traditional rides are vanishingly rare but very few people post videos that show this fact.
Anyway I was going to start scanning and uploading pics of these lovely old dynamos and things, but I have a new distraction which is that my birthday dinner which we had to cancel has apparently been rearranged for tomorrow and some guests have just messaged me to say they are coming. We need to get cracking with Xmas decs, food prep, all sorts, not least because I'm at the stroke clinic much of tomorrow daytime.
So hold your galloping horses for 24 hours and I'll be round again...
Ok Mr Ferris Wheel, holding our carousel horses 🤣
OK off we go, but not with the Mather and Platt dynamos yet because I can't find the pics. We'll start in the middle and just chat and post stuff and see where it goes.
Today, I want to take a first look at ride motors and their speed controls. In the era we're considering, most rides were driven by 110V DC brush motors. Either one big motor driving the centre of a ride such as a galloper, which could be in the range of say 5-20hp, or a number of smaller motors in individual cars such as you might find on a juvenile train ride. These motors differ in detail but almost every motor and indeed generator that we are going to meet at the fair is of the same general configuration: A wound armature fed by brushes on a commutator revolves in a stationary magnetic field.
These days, many DC motors have permanent magnets to create the field but for much of the history of DC motors, there were no permanent magnets strong enough to make an efficient, compact motor, so the magnetic poles on the frame were wound with field coils to form electromagnets. There are various ways the field coils can be connected - in series with the armature, in parallel (shunt) and a combination of the two (compound). We'll begin with shunt winding (see attached diagram) as this is the simplest way to produce a motor that runs at a steady, controllable speed. The field is not necessarily connected directly in parallel with the armature as there can be control resistances in either circuit. What we mean by shunt-wound is that the armature and field are energised separately from the supply voltage, so that their currents are independent and can be controlled separately. Note, this different to most small brush motors in household appliances and power tools, etc, which are series-wound.
Time to introduce some essential characteristics of ideal, generalised DC motors:
  • Torque is proportional to armature current and also proportional to field strength.
  • Speed is proportional to armature voltage but inversely proportional to field strength.
If we want a shunt-wound motor to run at a steady speed and be able to deliver maximum torque if the ride needs it, we must supply it with:
  • Full field current (this is normally limited by the resistance of the field winding itself, and is at maximum when connected directly to the rated supply voltage.)
  • Armature voltage to suit the desired speed. Again, nornally the rated speed of the motor corresponds to the rated voltage across the armature.
  • Whatever current the armature demands, to develop the required torque. The higher the mechanical load, the more current it will take.
Before this post gets too wordy, let's have some pics of drive motors. Here you can see the main motors on an octopus, ferris wheel, dive bomber and speedway ark, and for comparison the small motor on a juvenile ride. In the next post we'll look at the speed controls themselves.
I mentioned putting resistance in series with the armature circuit and labelled it 'starting resistance' on the circuit in the previous post. In due course we will need to look in detail at how armature resistance works both as a soft-start and as a speed control. It will serve both functions quite well for most rides, e.g. a twist or chairoplanes can be perfectly well controlled with a resistance. But its shortcomings will start to show when we apply it to the huge, heavy speedway, and an exploration of those shortcomings will lead us to the origins of the Ward-Leonard system and the wonderful 'Scenic Showmans' locos.
At the very elementary level, we can consider that adding resistance to the armature circuit reduces the armature current and therefore the torque, making for a soft start. But how does it control speed? In the next post we will throw some equations at the problem but suffice to say for now, with many kinds of ride, the more resistance, the lower the speed, so we want a variable resistance that can be cut out in steps.
Take a look at these controllers and the circuit diagram. There is usually a cage with resistance elements not unlike spiral heating elements, on which is mounted a faceplate control with studs over which the wiper arm runs. Each stud to the right progressively cuts out the resistance section by section, with the final stud being all out. There is usually a knife switch to the left which serves as both the emergency stop and for inching the ride for loading, while the controller handle remains on whichever stud gives a suitable creeping acceleration for this.
BTW some of these pics are from memorable days out. Resistance Controller 1, for example, is Michael Miller's 12-car big wheel by Eli Bridge (NFCA index BW23) at Barnet with Smith's fair in 1983. When I took the pic of the controller, I was 11 years old and Ottawan's 'Hands Up' was spinning on the turntable. You can see the whole thing in these pics at the NFCA two years earlier and you will see the generator that was powering it, in a later post.
The next post will be heavy with theory!
As seen in the above pics, resistance control of DC motors is popular, but what are its limitations and how can it be improved? To understand how the motor interacts with the resistance and mechanical load, we need equations. I stated as facts earlier that for an ideal shunt motor at constant field current, speed is proportional to voltage and torque to current. To turn those statements into equations, all we need to do is define a constant of proportionality, which says how many volts per RPM and how many newton-metres per amp that particular machine develops. The constant is more or less a description of the machine in a single figure, that takes into account many factors such as physical dimensions, number of turns of windings etc. We call it the flux constant, kΦ (phi):
ω = Ea / KΦ (Angular velocity (=2.π.RPM) is armature EMF divided by flux constant)
τ = Ia . kΦ (Torque is product of armature current and flux constant)
Ea is the EMF developed in the armature as it spins in the magnetic field. When a machine is running at its no-load speed (ignoring losses) the induced EMF exactly opposed the applied voltage and no current flows, i.e. it is in equilibrium, neither generating nor motoring. Increase the voltage or decrease the speed, and it starts motoring, with current flowing through the armature one way and torque assisting the rotation. Decrease the voltage or increase the speed and it starts generating, with current flowing through the armature the other way and torque opposing the rotation.
If we connect a supply of constant voltage Vs, again ignoring losses and internal resistance:
ω = Vs / KΦ (speed equals supply voltage over flux constant)
and since both the voltage and the flux constant are constant, so is the speed. As we are ignoring the losses, we find that the speed is completely independent of torque. We take some motor or another, connect it to 110V and it runs at 1200RPM. The more torque we demand, the higher the armature current, but the speed remains constant. This is not quite true of a real-world motor but let's assume it is for now in our ideal motor.
But now let us put a resistance R in series with the armature, as per the circuit diagram in the previous post. A voltage Vr will be developed across it, proportional to the current Ia and to its resistance, and this appears as the difference between the supply voltage Vs and the armature EMF Ea.
Vr = R . Ia (voltage across resistance is proportional to armature current)
Ea = Vs - Vr (EMF across armature equals supply voltage minus drop in resistor)
Therefore Ea = Vs - (R . Ia)
Now the armature EMF is no longer independent of its current. Substituting for Ea and Ia:
ω . KΦ = Vs - (R . τ/kΦ)
And likewise the speed is no longer independent of the torque. With constant supply voltage and field current:
For a given torque, the higher the resistance the lower is the speed
For a given resistance, the higher the torque the lower is the speed
So the resistance spoils the constant speed characteristic of our ideal shunt motor. If the load torque varies, so will the speed for a given setting of the rheostat control. In the next episode, we'll see how the nature of the load decides whether that is a problem or not.
Before we get into any more theory, here's a little video shot at the Great Dorset in 2018.
We can see and hear the effect of starting a big wheel ride under resistance control, on the steam showmans engine that is generating for it. The engine is Burrell Special Scenic 10NHP, Serial No. 4030 'Dolphin' built 1925. The ride is a 12-car Eli Bridge wheel, NFCA No. BW04 'Atlantic Star', built in Illinois in 1947, owned by Edward Howard.
With the engine running at a steady speed the dynamo is producing 110V DC and the ammeter is sitting at around 110A with the ride stationary, representing a lighting load of about 12kW. The wheel is embarking riders during the video and as each car is loaded it is nudged round to the next one every half a minute or so. As it accelerates, the ammeter swings up to about 170A, i.e. the ride motor is taking about 60A or 6.6kW. This probably translates to about 6hp delivered to the wheel itself. You can hear and see the engine come under load as the reaction torque of the dynamo increases. The canopy lights dim slightly while the engine governor reacts to increase the steam admission and restore the speed and voltage.
Dolphin was one of the very last Special Scenics built by Burrell, with larger LP cylinder bore and 10 NHP rating. Nominal Horsepower (NHP) was an old method of describing the size of a steam engine based on piston speed and bore, but it is not an actual rating of power equivalent to BHP (brake horsepower) or watts. Dolphin is capable of something like 80 BHP mechanical output, which depends as much on the evaporative surface area of the boiler as on the engine. Belted to the engine flywheel is the Mather and Platt main dynamo, I think a model P8C but perhaps not the original one.
Being a Special Scenic engine, Dolphin is also fitted with an auxiliary dynamo on a bracket behind the chimney. You can just catch a glimpse of it in the video, but it is not belted and not in use here. We will return to the subject of how the two dynamo system improved ride starting performance, but it's worth mentioning that the name of the loco 'Dolphin' refers to the original ride that it powered, the Orton and Spooner 'Diving Dolphins' scenic railway ride, which required the special starting arrangements due to the very heavy cars with individual motors starting against unbalanced static forces, unlike the relatively balanced big wheel or a flat ride.
Enjoy!
That was on the Saturday evening of the 50th anniversary show, which holds a Guinness World Record for the greatest number of steam-powered vehicles at an event (over 500). I did count the number of Showmans engines with their dynamos belted up that evening but can't remember now, I'm sure it was over 80. Some were powering rides, some powering organs, some were remaning free entities and just lighting their own canopies.
The Sunday was bizarre, there had been a storm overnight and heavy rain continued through the day. Half the exhibits were under wraps but Kat and I still had a load of muddy fun. One of the intrepid operators who was bracing the weather was David Downs who had his Tidman 3-abreast steam gallopers (G4) up and running. We walked up when no-one else was around and got an extra long and fast ride as the boiler had a full head of steam to be used up.
Just like the CV in the Citroen 2CV = chevaux-vapeur (so steam horses) :)
Quite a few countries had odd ways to tax vehicles based on the engine but for various reasons (probably simple but stupid) many based it on the engine size rather than actual output. As far as I remember the UK at one point had one on piston diameter which lead to long-stroke engines being common, if not terribly good, in 1940s cars (i.e. to get less tax band for a given displacement).
I have no pictures and modern tech' sees no need for such systems anymore but had a wire drawing machine that would pull a wire through several shaping dies, each die was proceeded by a motor and because each die was tensioned differently the motors all had to have automatic variable speed control, this was done with what are called dancers, the cable would loop around 3 pulleys, 2 fixed and a floating pulley, the floating pulley is attached to a variable resister as seen on the fairground photos which as the wire tightened or loosened would automatically change the speed demand on the following motor.
We usually had a master motor with user speed control and the rest were slave motors working off the dancers, effective but dated as you had to have a large DC gen' in the basement to tap a secondary supply of for your machines, wish I had the pictures, we had a lot of fun replacing the DC motors when the variable units failed with age, trying to match AC VSD's to seek a set point in torque feedback mode wasn't as simple as you might theorise unless you did the whole line, we hit many a tech' walls during the repairs, modern versions have several AC drives and are linked to each other in the controls still using dancers but using a linear transducer instead of a variable rotary resistor, the master speed control would maintain the master motor speed and drive control links would trim the voltage signal from each transducer return voltage, our issue was having an electrically isolated AC drive reacting to a line of DC motors, it was the reaction time of modern tech that often created a issue as it had no master analogue feedback and just looked at its own dancer, often we had to train the operator to manually ramp up speed in a certain way to allow a smooth start up, it was starting the lines that were the issue, many a snapped wire was done and with a 15minute set up time it was a long learning curve.
