Amp David
Mentor
Supporter
Looking to get a combined sounder and strobe light to indicate when a baler require manual intervention.
Can any one suggest any suppliers. Had a look around this morning but nothing stands out to me.
Cheers
what trigger voltage do you have to activate?
Used RS in the end, had dual voltage sounders and strobes.
Just been thinking regards fusing for the new sounder. As its away from the machine now, is it still acceptable to use the internal fuse on the machines control or should the new feed cable be fused separately from the sounder local to the machine?
If it’s not part of a safety system fuse it. Protect the rest of the internal system.
