Discuss Main Earthing Conductor Termination with SPDs in the UK Electrical Forum area at ElectriciansForums.net
Strima
Here's a question that I was asked earlier.
If you have SPDs installed in a DB is it permissible to terminate the main earthing conductor into the SPD first then the DB earth bar?
Or must it be terminated in the DB earth bar first then the SPD?
I have always terminated to the MET first and then taken a suitably sized CPC from the SPD to the MET.
This means you can replace the SPD without disconnecting the main earth for the installation.
Never fitted them in a domestic situation, only in motor control centers.
Its probably not necessary to run a 16sq earth to the SPD in a domestic installation so best do as Rob says, and a smaller link (4sq mm?) to the SPD.
Reply to Main Earthing Conductor Termination with SPDs in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
Has anyone fitted an SPD to a schneider standalone AFDD DB. Isobar P B Standalone Active distribution board, Acti9, 24 AFDD ways This board only...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
