If they supplier hasn't supplied an earthing facilty from the off, they are under no obligation to provide you with one now.
The way I see it, the customer either pays you £400 odd for a suitable Cu upgrade or £3000 to the DNO to PME their system and supply you with an MET.
Kind of a no brainer to me.
Apologies if I have the wrong end of the stick though.
2nd'ed......
3rd'd !
If the head is a BS 3036, they are duty bound to replace the service head free of any charges, in fact there is Nationwide drive for all such heads to be upgraded by a certain date!! If they start getting bolshy get in contact with the ombudsman and they will get it sorted...
It's a pity the OP didn't post up some of these photo's he's taken, so that we could have given a much clearer course of advise....
For purely academic interest, 3036 encompasses the rewireables and other equipment, presumably the cast iron heads?
Re: main incoming on att
You're doing your subtle quote editing again.
You did a brilliant one the other day!
This sounds like they must have new rules or just being stubborn. I live in the north west and about two years ago I had the same problem, rewired a house but was getting readings indicating a very poor earth, got onto the local DNO saying the house didnt have a proper earth and they needed them to check their incomer. They came out two days later tested it agreed with me and the stripped the sheath back on went the clamp and put a nice new earth bar on the panel for me and off they went, very simple very good. I would think that if it is a residential area a earth being supplied should be their issue to assume a safe system otherwise we would be knocking ground rods in everywhere! Correct me if am wrong!
Who is the DNO you are dealing with?
Only asking because I only ever seem to get grief from the supplier and not the DNOs
egginyourface,
Guitarist,
