Discuss Mains doorbell wiring in the UK Electrical Forum area at ElectriciansForums.net
Jemma
Hi new to this site
Was wondering if anyone could help me with the wiring on this mains doorbell please will attach a photo
Many thanks
Where is the rest of the bell? Why is there a phone cable in it??
There is no rest of the bell, it's all there including a 240 to 6v transformer.
The phone cable goes to the bell push.
To the O.P.
I assume its been taken of by the painter?
If the mains isn't connected under the top cover you need to get someone in.
If the mains is connected then one yellow on each screw on the top of the block they are hanging over numbered 2 and 3.
Then the Blue from the bottom cable onto the top left screw , no.2, where you've just put a yellow and the white to the bottom right screw with nothing on it looks like number 0.
To the O.P.
Many thanks for your help
#8, its a new build house. Get onto the developers and tell them to finish it.
Next there will be a question about 2 brown hanging out a square hole next to a door
Reply to Mains doorbell wiring in the UK Electrical Forum area at ElectriciansForums.net
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Hi, I have a Friedland 752 chime box in my living room which is the most ugly thing. We have not had a doorbell attached to it in the 5 years we...
