P
pyrosym
I am trying to use a pair of TP-LINK mains adaptors for extending the Wi-Fi in my 3 storey house. I cannot get the two units to communicate so I am wondering if it they would be affected by being on different RCD's of a split load board or would this not matter.
Does anyone know which conductor they communicate through?
i had some a couple of years ago, i even had trouble when they were transmitting through different mcb's. better off running cat5 to wireless access points if possible.
I've got them and they do work across 2 rcd's as long as the RCD's are in the same board. Do you have a 2nd fuseboard hidden away - that would make a difference.
They are both connected to circuits within the same consumer unit on 2 different RCD's but there are no further distribution boards. The board is new. If they work on the Line conductor then I can't see why it wouldn't work. If it were CPC or Neutral they are separated in the board so the RCD's dont unbalance themselves I guess that would prevent them from working.
I may just have to bit the bullet and run a cat5 to the wireless it's just a pita route to do it.
Silly question but have you tried moving the TP link device to a "closer" socket and re-running the unility software to see if can then see it?
Hmm, I'll try putting them both in the same room and see if a laptop can see them it will at least tell me that the units work.
I think I'm probably going to exchange them for 30m of cat5. I could cheat and throw it out the roof window and pull it in through the letter box that will save me some house bashing!
pyrosym,
pyrosym,
